- Aug 10, 2019
- 2,556
- 5
- 0
HI all
A bit of a strange one this, and wondered if anyone seems to have encountered this.
When i listen to my system for 30-40mins i get a dull pain in my right ear ( before you say turn it down it happens at any volume) it seem to happen with what ever hi fi i buy. Normally im able to sort it but it can take some time, In the past its been silly things like doors vibrating on the door frame but it can be as simple as vie had the wires the wrong way round, positive/negative thing.
In the past ive had surround sound systems and this has happened it turned out to be the levels to low or even too hi but this time i cant seem to pin point the problem all the wires are in the right way round. Don't know if any one has any opinions or experiences on this any help would be great.
My other Question is QED original speaker cable directional ( i don't seem to be able too see any arrows) just wondered if this had a bearing on this problem or not?
I also have a sound pressure meter and i have set the speakers accordingly 75db which i have read is about right i think and all the distances have been set and measured with a tape measure.
look forward to your responses
