I wonder if anyone can help with a problem I have. I recently bought a used Rega P3 complete with RB300 tonearm and Linn K9 cartridge.
I replaced the K9 as I didn't know anything about it's age and replacement stylus are no longer made. I decided on the 2M Blue and after reading many cartridge set-up guides and investing in a mirrored cartridge set-up protractor and tracking force gauge I installed the Ortofon. However, I get horrible distortion in the midrange, even on very quiet sections, especially on strings. For anyone that knows it, Tanita Tikaram's Cathedral Song on Ancient Heart is particularly bad.
I can only remove this distortion if I reduce the the tracking force to around 1.3g but this seems way off the Ortofon's spec (1.6 to 2.0g). Although it now sounds great, I feel something must be wrong somewhere and I'm worried running it this light could damage my records. I did notice that the tonearm wasn't level so raised the counterwieght end by 4mm using spacers but this has not helped.
Any hints or tips would be very much appreciated.
Thanks, Craig.
Thanks, Craig.
