chebby
oldric_naubhoff said:on the other hand. if piece of equipment lasts for 34 years and is still in good working condition why should we expect it'll collapse soon after we buy it?
Why indeed?
Baffling isn't it?
chebby said:oldric_naubhoff said:on the other hand. if piece of equipment lasts for 34 years and is still in good working condition why should we expect it'll collapse soon after we buy it?
Baffling isn't it?
Why indeed?
chebby said:the record spot said:Which is fine if you're buying from a value for money perspective, but not everyone will be buying with that criteria in mind. Some will want new, so a 34 year old amp won't kick it for them, others won't want nearly 40lbs of amp sitting on their sideboard/rack, others will want more up to date technology onboard...
...or if they might want the peace of mind of 3 year/5 year guarantees on their expensive gear. I have had free repairs (major ones in some cases) on an LCD TV, an item of hi-fi, an Apple iMac and a Dell laptop in the last two years.
If they had not been covered by their respective 3, 4 and 5 year guarantees - because of being bought second-hand - then I would have spent a small fortune getting those repairs done by manufacturers (or their approved agents) with all brand-new parts (and shipped to and from my home free of charge). In the case of the TV we were even given a loan set for 2 weeks whilst ours was awaiting parts from Samsung and being repaired.
oldric_naubhoff said:chebby said:oldric_naubhoff said:on the other hand. if piece of equipment lasts for 34 years and is still in good working condition why should we expect it'll collapse soon after we buy it?
Baffling isn't it?
well, you don't think you'd be able to drive a car without any servicing for 34 years, do you? manual volume potentiometer is more mechanical part than electical so some level of wearing may be expected over such a long period of time. of course, potentiometers don't suffer such levels of mechanical friction as for instance wheel bearings but then again you don't need to make serices every 5 years or so.
plus after so many years you'd do well to replace caps too. they should be able to withstand many years of home use but after 34 years replacing (or indeed upgrading) them would be advisable to return amp's performance to its former glory.
audiosanctum said:A dealer willing to put his neck on the line;
1. Room acoustics
2. Match the speakers to the room
3. Match the amp to the speakers
4. Match the source/s to the amp
5. Match all with transparent cables
(Time to run for cover)
audiosanctum said:5. Match all with transparent cables
1. Room acoustics
CnoEvil said:dealer escapes with credibility intact. I like it. Cno
