Has anyone else here left the dust covers on their speakers too long and ended up with two tone speakers as a result?! I took mine off for the first time in a long time and the cabinet area covered by the dust cover is considerably lighter! Does it even itself out after a while if i leave them off for a good while?
Big Chris
400
That can be an issues with real wood veneers as they fade in sunlight over time. I doubt if it'll even out unless you can cover the part that's already been sun-bleached.
My dust covers only ever get put on when friends/relatives bring their brats kids around.
Frank Harvey
567
We usually find a few models tend to do this after a while - it's usually lighter, beech/maple type finished that it show up on more.
roger06
374
Big Chris:
My little boy (20 months) generally doesn't touch the Dynaudios but insists on trying to put the grilles on when I want them off!
I have a similiar problem i have to over come at work with dust covers on dining tables. Use T-Cut or watered down white tooth paste on on a area hard to see. Varnish or laquer is basicaly a clear paint so it responses well to t-Cut, is excelllent on watet stains too.
Vance
An interesting suggestion! Im just going to leave the dust covers off for a good while and see if it evens out a bit, as i would think the lighter wood should darken up quite a bit no its not covered by dust covers? If that fails i may try the t cut route, but the natural oak finish on the neats is quite a textured grain so im not sure if that will affect the outcome........
