Onkyo TX-SR605 video upscaling queries
I understand that the Onkyo upscales video. My questions are:
WIll it upscale any SD picture via component? (i.e an old non upscaling DVD player)
Would the upscaling on the onkyo be better than the upscaling via PS3? (i.e should I turn the upscaling on my PS3 off and let the Onkyo do it)
Is it able to upscale the freeview tv inbuilt into my lcd tv?
Sorry Strodo, only the TX-SR875 upscales to 1080P. You'll have to use the PS3.
Clare Newsome
1,657
He's right.... the SR605 doesn't upscale. It will, however, accept any video signal, deintelace it if necessary and allow it to be outputted via HDMI. So, more convenience, less wires.
Bit confused why you'd want to use an old DVD player when you've a PS3, mind you... (unless it's a multiregion machine, of course. The PS3's not too hot on that).
Re your TV - it'll be upscaling Freeview to fit its resolution already. Some scalers in TVs are better than those in players (or receivers), so it's always worth experimenting to get the best possible picture.
Hi Clare,
That's the clearest answer I've seen on the 605 'upconversion'. There is much confusion out on the web on this point. I'm considering buying the 605 and have been trying to get to the bottom of this feature. The manual and specs just state 'upconversion' of component (and other analog) to HDMI. After much research this is what I think the 605 provides, I would be most grateful if you could confirm (or correct) my understanding:
1. HDMI input will just pass through unchanged to HDMI output and will support all progressive and interlaced formats in common use today (486i, 576i, 720p, 1080i and 1080p)
2. Component (and other analog) inputs can be upconverted to HDMI outputs. This will at most de-interlace and will not change the resolution. Examples: 576i component in -> 576p HDMI out (my intended use with an old Sony DVD player).
3. There is talk of a secret option to upscale to 720p (e.g. feed in 576i on component and output 720p on HDMI). This is clearly not supported by Onkyo. This often causes confusion, I've seen many posts claiming this as a feature of the 605 - like its there in the manual. In my opinion upsupported features are misleading - I want to use products as intended by the manufacturer, not experimental/test features.
4. Being new to this field I'd like to confirm my understanding of the follwing terms:
a) Upconversion: Changing the format of the signal, e.g. analog to digital, and possibly de-interlacing to progressive.
b) Upscaling: Increasing the resolution of the image by interpolation / digital processing.
Paul
Can anyone confirm (or correct) my findings above before I buy. The manual is not very clear on these issues, but after much web trawling I think I've got a good summary.
Paul
