- Aug 10, 2019
- 2,556
- 4
- 0
Hi all,
I am a beginner when it comes to home cinema and hi-fi systems, so I would appreciate your views on what I should do. My problem is that at the moment I have one TV (Pioneer PDP-427XD) and the Telewest (now Virgin Media) HD box. I was thinking of buying a system (total cost up to £5K including the speakers) that will allow me to watch DVDs but also perform extremely well with CDs (audiophile quality). Also, I do not have a lot of free space, so at the moment I only want to buy a pair of speakers only, I want the system to allow me to expand later.
Initially (because of the lack of space) I was thinking of a one box solution (Arcam movie or Naim n-Vi or Meridian G95). I heard the Arcam movie and I was ok with the CD performance until I heard the Arcam DV139+ Arcam AVR350 combination. The difference was huge (in my opinion!).
So my first question is, do you think that the Meridian or the Naim can match the sound you get from the Arcam separates? Are two boxes always better than one?
Assuming that the answer is that I should go for the two boxes solution, what combination of AV AMP and DVD/CD player you would recommend that will give very good DVD performance but very very good CD performance as well? The AVR350 seems to me to be behind the competition in terms of specification, but for example I am not sure if the DV139 with match well with the Onkyo TX-SR875... Also do I really need to get the DV139 which is quite expensive or can I get similar sound from the Marantz DV7001?
And of course there are the speakers... Which one would you recommend for my needs?
Thank you very much in advance for your views and help. I hope in the future to be in a position to contribute something back to the forums after I get some experience with hi-fi systems.
