Onboard Chromecast Quality - Same as CCA's ?
Witterings
838
554
11,770
Does anybody happen to know what the quality of onboard / built in Chromecast audio is if it's part of an integrated amp and if it's any higher resolution / bitrate than the Chromecast Audios are which I believe max out at 24/96 and 320 kbps
Correct as far as 24/96 is concerned.
320 isn't, that's Bluetooth running SBC
Chromecast is lossless so the bit rate is 2x24x96= 4608 kbs assuming linear PCM.
Reactions: Witterings
