Question Odd Issue with Pro-Ject DS3 B Phono and Pro-Ject DS3 Sources Power Supply Trigger
newelement
Greetings,
I have a Pro-Ject DS3 B Phono and a Pro-Ject DS3 Sources power supply. I'm trying to use the trigger out from the power supply to control the phono via 2.5mm mono trigger cable. I'm not able to get the phono to turn on when I power up the power supply and I used a volt meter to verify the trigger cable is carrying the 12v load needed. Both units are 1-2 months old ( in my possession). Is there something I'm doing wrong or has anyone else experienced the same issue?
