micks_address
159
well if you can get a 'good' v20 the black levels are very good on it.. 'bad' v20's have very obvious buzzing, floating blacks, poor handling of 50hz hd material (i have not had this problem) and posterisation.. i would recomend auditioning a v20 and if your happy with one, audition the one you are buying.. if its ok.. then run home with it fast!
hughesyboy:
Which do you guys think is best for HD Films in a relatively dark room?
Philips 40PFL9704?
or
Panasonic 42V20?
