Hi guys,
Following my previous post – http://www.whathifi.com/forum/home-cinema/new-51-speakers I've gone for the Jamo S 426HCS3 speakers.
They are arriving today and I'd like a little help regarding setting them up. I've got a Sony STR D800 amp and will do the auto calibrate to begin with to get the distances etc relatively correct, but I reaslise I will need to tweak some settings:
What should the crossover frequencies be? Is it just a case of setting it to the lowest frequency range of the speakers?
Also, many people recommend setting the speaker sizes to small - is the the right thing to do for the front left and right speakers when they are floorstanders?
I'm a bit of a novice when it's comes to the nitty gritty of home cinema setup so would appreciate any help!!!
Thanks in advance.
Thanks in advance.
