matthewpiano said:The biggest issue with the Brio-R is the slightly cheap look. This 're-design' doesn't really address that and if anything the new volume control looks even worse.
However, I doubt Rega would release any new product simply as a cosmetic update. I would think there will be some worthwhile internal changes, hopefully including more successful shielding of the transformer from the signal path.
Is that a headphone output I see on the front??
Not for Rega turntables. They have no earth lead. But this isn't without its issues, as a glance at the Turntable section of this forum will show.stereoman said:Looks nice, where is the "ground" point for the phono input ? Is it not necassary ?
Probably on the under-side of the unit at the back, as it is on the current Brio-R.stereoman said:Looks nice, where is the "ground" point for the phono input ? Is it not necassary ?
manicm said:Update from the horses mouth. Volume control looks intriguing - is that a glass center? Regal needs to embrace digital though - why not a matching streamer?
tino said:manicm said:Update from the horses mouth. Volume control looks intriguing - is that a glass center? Regal needs to embrace digital though - why not a matching streamer?
Ditto - I think the central part of the volume control could be hiding a display of some sort? Also, like the Cyrus One, why no digital input?!? *unknw*
Completely disagree with you, the old volume knob looked like something from Maplins. This one, at least, looks like it's been custom made and looks quite nice IMO.matthewpiano said:...the new volume control looks even worse.
Each to his own. I actually think my A400 is much prettier than either of them, and a better amp than the Brio-R too (can't comment on the forthcoming Brio obviously).Diamond Joe said:Completely disagree with you, the old volume knob looked like something from Maplins. This one, at least, looks like it's been custom made and looks quite nice IMO.matthewpiano said:...the new volume control looks even worse.
Al ears said:tino said:manicm said:Update from the horses mouth. Volume control looks intriguing - is that a glass center? Regal needs to embrace digital though - why not a matching streamer?
Because if you have a digital input you'd need to incorporate a DAC section and thus push the price up. There is a reason to keep a simple amp in your line-up.
manicm said:Al ears said:tino said:manicm said:Update from the horses mouth. Volume control looks intriguing - is that a glass center? Regal needs to embrace digital though - why not a matching streamer?
I certainly didn't say that, I want Rega to offer a matching seperate streamer. That's a glaring omission in their line-up. They have a pure DAC, but I still don't see any value in a standalone DAC when many streamers have digital inputs as well.
Hi,drummerman said:manicm said:Al ears said:tino said:manicm said:Update from the horses mouth. Volume control looks intriguing - is that a glass center? Regal needs to embrace digital though - why not a matching streamer?
Agree. A DAC/Streamer makes sense but pure Streamers in this day and age when you can buy a CCA for less than a meal out for two doesn't make to much sense anymore imho.
shadders said:Hi,drummerman said:manicm said:Al ears said:tino said:manicm said:Update from the horses mouth. Volume control looks intriguing - is that a glass center? Regal needs to embrace digital though - why not a matching streamer?
What is a CCA? I looked it up and could not find out what it means.
Does not a dedicated streamer allow you to see which tracks are playing etc., without having to switch the TV to the streamer and interrupt the picture.
This means no cost of a NAS, or a noisy PC which may be wasting power.
Regards,
Shadders.
Hi,drummerman said:shadders said:Hi,drummerman said:manicm said:Al ears said:tino said:manicm said:Update from the horses mouth. Volume control looks intriguing - is that a glass center? Regal needs to embrace digital though - why not a matching streamer?
Regards,
Shadders.
That's what a Chromecast (Audio) ala CCA does.
30 quid or less.
