Do you have any kit atm, or buying from scratch?
If buying from scratch, I'd recommend you have a listen to a few different options.
If you're someone who gets itches to change things, I'd also recommend that you listen to a wider range of systems to get an idea of what they do.
Generally it is thought that systems with a separate receiver and speaker package give superior sound to 'systems in a box'.
