Out of interest Steve, how would you rate your Onkyo amp compared to the Linn Sneaky? The Onkyo gets really highly rated around these parts, and gets compared to much more expensive amps, so it is interesting to me that you like the Sneaky so much.
Neuphonix said:I realise that this might be a little too revealing at times but I would think that it will be a good match for the AMS35i, it should add a certain warmth I'm hoping.
Neuphonix said:I would probably run a second cheaper set of speaker cables from my RX-Z7 to the fronts & when I want to listen to music unplug them & connect the AMS. It's probably not quite as wife friendly but I like the thought of not having to turn the AMS on every time I use my system & the simplicity of Linn/AMS only for music. Less power consumption, less wear on the AMS. There is the possiblity of a speaker switch box but I would have some reservations about introducing another junction in the speaker cabling & it's effect on SQ.
Any thoughts? I seem to remember that you mentioned you do have the AMS/Arcam connected, but for TV you often don't turn the AMS on, centre only?
CnoEvil said:I often use just the centre + rear surrounds, especially for stuff that isn't 5.1. This works for me, but I appreciate that it mightn't be for everyone.
gregvet said:CnoEvil said:I often use just the centre + rear surrounds, especially for stuff that isn't 5.1. This works for me, but I appreciate that it mightn't be for everyone.
IMO this is the AMS's biggest (only?) failing, and the reason why I couldnt have one as part of my main system. No HT bypass option.
Shame really, as Cno has almost convinced me in every other area 😉
Neuphonix said:....
But now I come full circle, after all the HT integration considerations I think that I will just use the Yammy for HT & keep the AMS for music! Hhhm, expensive circle.
acalex said:Greg, have you actually heard the AMS yourself? I say so because once you go and listen to it, every other issue just disappears when you realise what this amp can do to music...
Neuphonix said:I find for TV that the centre is more than enough, even for stuff which is labelled as 5.1 almost nothing comes out of the fronts anyway. And for alot of TV which is dialog heavy having srround is completely unecessary (for me). Obviously properly encoded DVD/Bluray is another matter entirely.
In terms of having the AMS hooked up to the pre-outs of the HT processor but leaving it turned off, do you see any problem with the HT still trying to send signal to the AMS? ie. an electrical current is being sent but not used. Could this pose any issues to the AMS?
Something to play around with when the Akurate arrives. The more I think about it though the more appealing I find the idea of a separate music/HT set-up. The simplicity of source/amp/speaker for music without having anything else connected (even if turned off). In some ways its more wife friendly & in others not.
After my incident I have been looking at trying to minimise the number of devices rather than keep adding, but its hard...... 😉
gregvet said:acalex said:Greg, have you actually heard the AMS yourself? I say so because once you go and listen to it, every other issue just disappears when you realise what this amp can do to music...
Haha, nice try Acalex. I'm not falling into that trap quite so easily :rofl:
Im 90% sure if I heard one I would have to have one, and the lack of HT bypass would be an issue for my other half. No matter how good it sounds 😉
gregvet said:Yes Cno, David has promised to organise a comparative demo of Fact 8 v Kef REF 205/2, and I am still not sure which way I would go.
He hasnt promised the AMS yet tho 😉
gregvet said:.......and I have been banned from any more HiFi related purchases for the moment by HWMBO.
CnoEvil said:I'll write you a note! :shifty:
gregvet said:CnoEvil said:I'll write you a note! :shifty:
Unless you are a doctor, I'm not sure how a note will help.
CnoEvil said:Docter schmoctor, I've got special dispensation from the Tánaiste! :roll:
gregvet said:CnoEvil said:Docter schmoctor, I've got special dispensation from the Tánaiste! :roll:
Im not sure special dispensation from Eamon will hold much sway with him indoors, but thanks anyway. He's not quite as forgiving as Mrs Cno.
