There's no such thing as a friend.
Price for iPhone 13 As for how much the iPhone 13 will cost, we would expect prices to follow with the iPhone 12 range - $ 699, $ 799, $ 999 and $ 1,099 respectively. Apple tends to maintain its pricing for each new generation of iPhone relative to its predecessor. A TrendForce report says that the pricing of the iPhone 13 should be "relatively equal" to the current iPhone 13 models. Unfortunately, the company also says that the iPhone 13 Pro models will not have a 1TB storage option. Various rumors Point to the new iPhone that comes in the same four sizes as the iPhone 12: 5.4-inch iPhone 13 Mini, 6.1-inch iPhone 131, 6.1-inch iPhone 13 Pro and 6.7-inch iPhone 13 Pro. The new iPhones have appeared in regulatory reports with the Eurasian Economic Commission; The filing included seven models, though it could come in different configurations. Four models in the fall - at least for now. (According to reports, Apple is developing a foldable iPhone, but the latest rumor suggests a two-year iPhone launch) There iPhone 13 Early rumors about this fall's iPhone have used the iPhone 13 as the upcoming model name, since Apple switched from the iPhone 11 to the iPhone 12 last year.A handful of rumors referred to the new iPhone by the iPhone 12s.However, although we will not know about it Certainly what it will be called until its release, a new report claims that Apple will still stick to the name of the iPhone 13. According to sources and supply chain tests, the report in the Daily Economic News says the iPhone 13 array will reflect that of the iPhone 12 in both name structure and models. The iPhone's model usually suggests that the phone has a lot in common with last year's version, except for a few major improvements. So whether Apple goes with the iPhone 12s or the iPhone 13 as a name, say a lot about how the phone this year is really different. Interestingly, according to a survey of 3,000 Apple users by SellCell, 18.3% said they would avoid buying a product called the iPhone 13 because number 13 was unlucky. Most respondents preferred to list the devices after the year of sale, with 38% supporting a not-very-Apple-like iPhone (2021). 16% said the company should skip straight to the iPhone 21. Apple will likely achieve this slot reduction in the new iPhone by combining the infrared floodlight, sensor and dot projector, which make up the iPhone 12's Face ID locking system, into a single module. With two less sensors required, we should see a much narrower slot in the iPhone 13. These rumors seem to be backed up by dummy units of the
iPhone 13 leaked on the Weibo, featuring the small cameras and diagonal cameras. A separate report from Digitimes says that the die size of the VCSEL chips used in the Face ID scanner will be reduced by 40 to 50%. As a result, a smaller Face ID chip may have a smaller slot for the iPhone 13. The earpiece speaker could no longer be housed in the slot, and instead moved to the top frame, according to a dummy unit of the iPhone 13 Pro Max, which features the new design and smaller slot.
