New Goldring cartridge line up.
Al ears
It is very interesting to see a very forward-thinking Goldring issuing a new range of easy-fit starter cartridges as upgrages to start-up turntable packages but are the going to be bought?
Being Goldring their quality is unlikely to be questioned however looking at those RRP prices I would ask if they are likely to be a big step up from the usual suspects that are fitted to starter packages. Is anyone who only has the funds for a starter deck even going to consider replacing the pre-fitted cartridge with cartridges such as these? Not immediately upon buying the deck I imagine.
I was intrigued at the apparently quite close pricing, rather than say, £60, £120, £180 or something similar. Didn't see any explanation of what changes apply at each level either from the WHF news item, so presume three stylus types but otherwise identical. Have you seen any specs?
No, and there is nothing on the Goldring website yet either. Presumably these will replace the current Elan / Elektra cartridges which simply have differing stylus profiles as you suggested.
Thanks, Al. Must keep a look out for them as it would be nice to have a decent alternative to suggest instead of the Ortofon Red.
I'd recommend my Grado more if some folks didn't find hum problems and the odd issue of LF 'wobble', neither of which I've been afflicted with. I think they have a great midrange, and the extreme LF and HF is just a bit too subdued - though it helps mitigate surface noise.
One would assume that if the user has the funds for the top of the range, they would go for the moving iron line.
SERIE E
For more than 100 years, the Goldring philosophy has been to promote the precise replication of the original recording, maintaining the creative nuances, musicality and rhythm that the artist intended for you to hear. With the E series, this is achieved with the three capsules in the range that have been designed to capture this musical experience when used with the medium to high arms that we find on most turntables of a reasonable price level.
All capsules in the range are based on Magnetic DuplexTM technology, which achieves a more accurate stereo reading. With spherical needles and choice of cantilevers, the E1 and E2 models are ideal as an upgrade to any obsolete or low-end capsule. The E3 model, with its perfected elliptical needle, is a valuable improvement for those who want to extract all the information and detail possible from the grooves of the vinyls.
SPECIAL FEATURES
Magnetic DuplexTM Technology
During the recording mastering process, the cutting tool records stereo information as a V-shaped groove that has perpendicular walls at a 45-degree angle. Conventional mobile magnet capsules use a single large magnet that interacts with two coils mounted vertically to produce the stereo signal from the groove. This can introduce crosstalk and only offers a modest amount of stereo separation.
The Goldring E-Series capsules have a special double-magnet arrangement. Magnetic DuplexTM technology uses two low-mass magnets that interact only with their corresponding pickup coil. This allows the capsules to follow the groove of the disc more accurately, since they emulate the geometry of the cutting head, obtaining a better stereo separation and a more precise, surround and musical sound scene.
Expert Adjustment
The horizontal reading angle of the needle (azimuth) should be parallel to the vinyl for optimum performance. An incorrectly adjusted azimuth results in an unbalanced balance, an increase in crosstalk and a serious degradation of the stereo sound scene. This is a parameter that can rarely be adjusted by the user, so it is vital that each capsule comes out of the factory with precisely adjusted azimuth.
The E-Series capsules use an adjustment screw specially designed to locate the cantilever, instead of a standard pin, allowing microscopic adjustments during production. This pre-set azimuth implies that the crosstalk is optimized and can install the capsule on any turntable without making corrections.
