deanhartley:
Hi, I would not advise disconnecting a bass driver. This will not work very well. The two lower bass drivers are connected in parallel, so disconnecting one will ensure you end up with a driven unit and a passive unit (ABR), but the ABR will then not be optimised and will create and odd response.
Essentially it sound like you have a room acoustic problem, which could be a combination of room dimensions causing a dominant room mode. You will not cure this by swapping them for a different floor-stander. If you cannot treat or re-arrange the room, then the only solution is to get a speaker with significantly less bass output. I would actually recommend swapping your speakers for a book-shelf speaker. If you consider MA, then there is the GS10, a fairly full size stand-mount. You will find better mid and H.F clarity with much less bass energy, although still quite well extended. These are soon to be replaced with the new GX series and the GX100 will be at Bristol. There is also the smaller GX50, which is stupendous for the size. It's a really cracking little monitor and around the price you are looking at. The GX also steps up to using a ribbon tweeter, so you will get very clear, extended H.F with no hint of zing.
Because of the problems you have with your room though, don't buy anything without trying it in your room.
If you really want to try something with you current RS8's quickly without resorting to opening them up, then try this:
Go to Maplin and buy some 10W ceramic resistors with a values of 2R2, 3R9 and 6R8. You can only do this if you are single wiring, not bi-wiring BTW. Place the speaker cables into the top set of terminals, which actually power the tweeter and top mid driver. Place one of the gold bi-wire links between red top and red lower terminal. Remove the gold bi-wire link between the Red top and red lower terminal. Place the resistor between the top red and lower red terminal. This will actually get a little warm (perhaps even hot) when being used. However, this will just give you an idea of the type of bass attenuation you can expect. You can try the 2R2 version first which will give you an attenuation of around 1.5dB. If this is not enough, then try the 3R9 version which will be -3dB. 6R8 will attenuate by around -4.5dB.
I am not completely sure of the results you will get, because it will also cut down the mid-range output as well, but it may also do the trick.
Give it a try and see how you get on. PM me if you have any trouble.
Good luck
Hi deanhartley
I have tried to find these ceramic resistors on maplin site but couldn't see anything like it.
Anyway i think that you are right about my room acoustic and that floorstanders won't be a good option for me at moment.I love the design of the new GX range, which is what i was looking for and wife will be happy too
I am looking forward to demo GX50 at Bristol show.Will i get a chance to buy them there in a good price eventually ?
