- Aug 10, 2019
- 2,556
- 4
- 0
Having bought the Toshiba sd340 (?) a few years ago (and finding it tempremental even then), and a bush dvd recorder, these both seem to be on the way out.
the bush usually takes about 4+ presses of the eject button to open, and sometimes only responds to the remote control (or not at all) as well as freezing up. the tosh usually works, but the disc tray almost never slides back properly so it needs pushing in manually.
as a result i think it's time to chuck the bush (now have pvr for recording) and relegate (or bin) the toshiba.
the question is, do i buy another dvd player which upscales to 1080i* for about £80-100, cheat and use the xbox360 (picture to me seems as good as current toshiba - but then upscaling should make a difference right?), or future proof and buy either the ps3 or panasonic bd30 (?).
I guess the main question is: how soon do folks expect to see a price drop in well performing entry level blueray players? (this is a very open question i know)
I'm not that fussed in being in the first batch of friends to get technology so am quite happy to wait a while if it means cheaper/better performance when i do buy.
thanks for any advice.
*1080i as my projector wont do 1080p
