new av rack help
No, I mean the space in your room that you wish to fill with some AV shelving.
i only have denon x4800h and panasonic 4k player and i would put dali rubikore cinema on top shelf later. should s2-3 will suffice? s3-3 is not available in my country. i can also go with Vulcan pangea 4 shelves it costing me 48000 but s3-4 will cost me 64000
Apparently the S4 range has wider shelf space than the S3 range and can hold more equipment than the slim ranges.
Review of the S3-3:
View: https://www.youtube.com/watch?v=hMzjCuMfauw
i only want to put panasonic 4k player denon x4800h and dali rubikore cinema on top of shelf. thats all
I am obviously not saying clearly enough. I don’t know! (Why don’t you measure it for yourself?)
Reactions: hardcore_gamer29
measured. s2-3 will suffice. but why s3 is costlier than s2
Looking at a comparison between these 2 the S3 might hold more weight but that won’t matter with you:
These 2 are basically the same stand.
Yes, this is the case the Solidsteel website comfirms it here:
The S2 holds 50kg weight per shelf and the S3 holds 60kg of weight per shelf.
ty bro saved money
Reactions: Holt
