Need Twonky help
iburnell
21
Anybody familiar with Twonky ??
I have ReadyNas Duo -> Naim Uniti. CDs all ripped into Flac with DBPowerAmp and all is fine.
Only issue I have is I'm using the N-Stream app on iPad2 to control and get no cover art.
After various threads the suggestion was to install the Twonky add-on. Having done this you get the option to "merge" in any existing Share(s) - which in my case I just called Flac. This works ok, but I now see two upnp servers - the original nas one and the Twonky share but no cover art on either !! I wondered if you have to copy all the flac files over to the Twonky share ??
anyone done anything like this ???
I use a Synology NAS and initially had a similar problem to you with the artwork. Turned out there was an unchecked tick box within the (pre-installed) Media Server which needed checking to decide between low-res and hi-res versions of the artwork.
Box ticked, artwork appeared fine. Worth checking the settings first before installing anything extra.
EDIT: Whoops, sorry, just read your last paragraph!
