Hi all,
So I'm about to do an upgrade of my hi-fi system.
Some background info first: I only use this for music. CD, vinyl and tuner (radio). No home cinema stuff (I like to keep those separated).
Currently I have:
- An old Onkyo R1 receiver (got this from my dad who didn't use it anymore)
- A Sony CDP-XE370 cd player
- A Gemini PT-2000 turntable (got this as a gift, not gonna swap it for now)
- Mordaunt Short Avant 902i bookshelve speakers on Mission Stancette speaker stands
- Very basic wiring (no expensive speaker cables)
I have my eyes on a pair of used (but in perfect condition) B&W CDM7 NT's and would like to buy some mid/high range Marantz components later on (amp, cd-player and tuner since I now have a receiver but want to use it as a radio as well).
My questions:
1. Will my current setup be sufficient to run these speakers?
2. Is the speaker upgrade significant? Even if I would stick to my current setup? I take it that's a yes since I'm going from bookshelves with just a woofer and tweeter to a higher range brand floorstanding speaker with a Nautilus tweeter with a separate cone bass for midrange.
3. What kind of amp would you advise with these speakers? One of the lower range Marantz amps (like the PM5004)? I could get a pretty good deal on a Marantz PM-KI Pearl lite, would that be a huge difference? If so, in what way?
4. What's the difference between the entry level Marantz cd players and the premium stuff?
5. What kind of speaker cables should I use? Do these really make a difference?
6. And lastly: would you recommend a receiver rather than an amp? (since I'll be using it for radio as well). I could get a pretty good deal on a Marantz ST6003 tuner (unfortunately in black, would have preferred silver.
That's pretty much it. Hope you guys can help me out, I have some knowledge on this kind of stuff but not nearly as much as a hi-fi enthousiast.
Thanks in advance!
Currently I have:
My questions:
Thanks in advance!
