Nad C316BEE V2 connected to my pc as well as the Q acoustics 2010i, height of the speaker to low and to much refelctions from my desk
Q acosustics 2010i sounds better on my tv rack,furniture in front, so theres less reflections in the low frequencys and perfect for tv with my nad mini dvd c717 system
Yamaha HS7 95watt total from each speaker oh boy they are loud, can play bass and are clear open (slighty bright compared to the new nad c316 and q acosustics 2010i)
My Nad 3020i need's 150mV for max power in 8ohm, Nad C316 BEE V2 need's 200mV, guess 150mV would be 30 watt in 8 ohm? (C316bee v1 and v2 have 40 watt in 8ohm).
My nad c717 has 20/30watt in 6 ohm enough for tv and concerts.
First impression, sounds different and can't play more than loud.
One thing i remember about the first c316bee was that it could sound slightly bright, v2 doesn't sound bright like marantz,denon,cambridge, that's actually a good thing (mabye a good match for dali zensor), i use supra classic 2.5 speaker cable, inakustisk usb cable , Focusrite iTrack lightning soundcard and klotz inteconnect to the amp (klotz cable just under the best qualiy, supreme, best is high end) q acoustics 2010i and tidal hifi/youtube.
Not bright or above avarage in openess and clearity (still very new "burn in"), sounds very neutral, might make a difference on the finer details but it's undeniable an advantage, less intrusive,fattigue than bright sounding systems,amps at high volume, should not be a problem pairing it with speakers a bit to the brighter side or qed speaker cable, which i feel is to the brighter of the neutral side when you go above the qed original.
For the size of the Q acsoutsics 2010i the bass is quite punchy, enough for most people for a computer, even in a mid sized room there would be enough power/bass. Still my personal budget speakers,even above 3010, even when i have only heard the 3020.
Midrange sounds neutral no screaming,shouting about the midrange
After more than 2 hours im getting use to the bass,the max power and the more neutral sound, as often the sound could change more after more hours of burn in.
Neutal sound,good bass and power(watt), looks good,the quality of the amp feels above avarage, don't get hot as hell as the Nad C326BEE does.
What i don't like so much is the firm volume knob, not at al as light to use as my 3020i (still the same problem om both versions of the nad D3020), for me it isn't but for some it might be, theres no soft clipping, price where i live is close to the Marantz PM6006, where the PM6005 (i owned one) is brighter more open an there for could be the better choice, i did fell the bass even on my 8005 wasn't more than avarage a litte restrained,subtle
Even the marantz PM5005 which is about 1/3 cheaper than the new nad c316bee v2 have removable power cable so it's possible to upgrade it, i wouldn't mind that on the nad instead of the remote (power cable makes a sound difference a remote doesn't).
Wouldn't mind the price differnce was a little bit higher compared to the marantz PM6006, in my country 2299 for the nad and with a discount Marantz would cost 2499 of my currency.
Have to admit im a bit of a nad fanboy, have had including the ones i have now, 9 nad amps in less than 4 years
