NAD C 546BEE / NAD C 356BEE Is this best combo for metal?
Shaun729
Is this the best combinaton for metal? NAD C 546BEE / NAD C 356BEE also which speakers for a small room under £450 that will balance out the sytem? In Australia the Marantz is more expensive than the NAD.
toyota man
79
Hi Shaun729 I take it you are into AC/DC Aibourne etc I saw Airbourne the weekend before last and they rocked out :rockout: :rockout:I was going to suggest a second had pair of mission 753 but I do not know if you would find a pair in oz good luck in your search
Shaun729
Thanks for the reply, good second hand hifi is extremely hard to get here. I've been thinking about BX2's or Dali Zensor 1's and Wharfedale 10.1 because they are good value here. By the way my best friend is an engineer at Toyota.
