Hello there. I have the b&w 685 s2 and nad 326 bee. I was looking for amp upgrade. Cause of nad is good with b&w and because of i don't have the opportunity to listen other...i decided to make a blind buy for the 356bee. On other hand i see the new one c 368 at the same money....i scared of the new technology....which one i should prefer and why?!
And some other questions. I play with j river. Usually se eq is in rock and always the bass from amp is max. Power cable is vovox initio and sound cable is kimber 8vs. Today i will try the 12vs. About power distributor i have a cheap one about 50euros crystal audio....if i buy other power distributor in about 200euros will i have difference in sound or not?! My dac is ifi micro with iusb 3.0 nano. Usb cable from laptop to dac i have the cable that was in box with iusb 3.0 and from iusb to dac the ifi gemini. I thought to change the cable laptop to dac....i buy a kimber but i had bass cut so i put back the ifi cable that was in the box. So maybe the ifi mercury is a good choise.i also see the VU 1 USB and wireworld starlight 7. At the end for interconnect i have the ifi interconnect that was in box. I buy van den hul the name but i didn't like so much. There is a upgrade for my dac called ipurifier2....but i don't know the results.Which part of all these can i change to take a good result without to spend a fortune?!
Thanks a lot
Thanks a lot
