After hearing various motors switch on through my house ring main I bought a ifiPower2, and used it to power my WiiM Pro Plus. To my amazement it stopped the blips, and removed a very faint hum that I could hear when the music was paused.I also believe the soundstage is better, which I wasn't expecting. After that improvement I bought a Tacima CS947 extension lead, which had good reviews and a WHF award. Continuing my 'clean up' I wanted to seperate my audio cables from computer cables and power bricks, so it was forty quid well spent.
My Mojo was previously charging from my P.C USB socket, but I gave it a new charger, plugged into the Tacima extension. Within a day the sound started to deteriorate, and after plugging and unplugging just about everything determined the charger was faulty- if the Mojo was run off its battery, no problem. I replaced the charger with another (Samsung) 1A charger, and thought nothing of it. Within a few hours' use the same thing happened. I have now employed a new charger (decent quality, I have three others which provide a good service for all my devices), plugged into its own mains socket, and everything is working fine again. Time will tell, but I don't expect it to fail away from the extension.
As it stands I can only think the extension was damaging the chargers, though as it is supposed to protect and provide clean (ish) power this is a mystery to me.My initial reaction was to return it. I am not experiencing any other problems from other stuff plugged into the Tacima. The ifiPower2 is still functioning as it should- I went back to the old WiiM charger and the noise returned, along with a dip in soundstage. I am 100% convinced it has improved my WiiM PP.
I am struggling to understand what's going on. Only the Samsung charger was rated at the recommended 1A, but aren't I correct in thinking a device will only draw the current it needs? The other two chargers are 3-way, and offer up to 3A charge rate.
Answers on a postcard please.
