- I have mine sitting on Granite worktop savers with sorbothane pads in between.
- To up end your speakers:
1. Get help
2. Do it on a thick Duvet.
- IMO The jumpers make a difference.....get the same cable as you are using.
- The only way you will tell which streamer to go for, is a home dem. The Kefs are very different to the Rega, and a forward punchy sound might be too much.....but you won't know until you listen.
- What is your budget for the Sub, and the size of room (HxWxD)?
- Remember the Sneaky DS is half the cost of the MDS, and is very good indeed.....thus you might get a sub and a source.
(At a later date, the Sneaky could provide a source for your second room, using the same NAS...when you upgrade to an ADS! :shifty: )
