my ipod classic has died! another classic or a touch
Joelsim I only spend £10.00 about every 3/4months on mobile use.
It is fine to plug your ipod touch it into your speakers while already playing, isn't it?
I doubt you'll do any damage, but I'd play it safe and use an amplifier or something between the Touch and the speakers...
Andrew Everard:I doubt you'll do any damage, but I'd play it safe and use an amplifier or something between the Touch and the speakers...
I mean portable travel speakers?
I did it yesterday now not sure if i am getting a bit of a distorting sound?
What do you think?
No, it's unlikely that the distortion, if there is any, is a result of you hot-plugging the Touch into the travel speakers.
If you have disdortion it might just be a lower quality song. Andrew did whathifi buy any Avi 9.1's for the active feature as Ashley was shy about putting them forward.
Thank's guy's i am pretty sure i am worrying about nothing.
Well I'm loving the flexability of my touch and the fact I can veiw the forum and in this case post a reply with it.
