Question My Hi-fi system is not working properly
bulduzer
Hello,
I recently bought a hi-fi component system from a friend. It has one problem that I can't figure out what is going on. I use RCA to Aux cable to play music from a mobile phone or computer, at first I thought it was the cable, so I bought another cable, but it's not, the same thing happens on the radio. So the problem is that sometimes only one speaker works and then I manage to solve it by turning the system off and on or turning the volume all the way down. To me it looks like there is some kind of break in the cables somewhere. I must mention that the speaker cables are not broken anywhere and P.S. It is Aiwa CX-Z900M.
bulduzer
Is there any crackle as you adjust the volume control?
Actually yes, it happens if I move the volume potentiometer a bit faster and then the sound works on both speakers, but not always.
Are you sure the speaker cables aren't at fault?
When you say one speaker doesn't work is it always the same one?
I'm not sure, but I don't think so, but for now only the left speaker works, and until recently it was the same with the right one. Right now, I am listening to some music and both speaker works, but I think it will just random "turn off" one speaker...
you possibly have a volume control that is corroded or dirty that needs a good squirt of contact cleaner
Gray
Channel dropouts can be the result of contaminated selector switches and (analogue) volume controls.
I think yours has soft-touch (electronically controlled) source selection...so it won't be that.
But you may well have the type of volume control that could benefit from some contact cleaner - sprayed within its metal casing.
Checkout Servisol Super 10.
You could get someone else to do whatever is necessary, but you shouldn't really want to be spending too much money on it.
Double- check all rear connections before doing anything else though.
twinkletoes
Might be worth just checking the fuse on the inside of the amp the ones that sits on the left and right channel. you can normally see them with a torch through the grill at the top.
Sometimes they melt and then reform when the amp is cold again
bulduzer
Here are pictures of the inside, I really don't see any break in the circuit board
This is the potentiometer inside, there is something greasy on it, I don't know if it is the cause of the problem or it has to be like that
Gray
The circular part with the grease on it is not the potentiometer, but a motor (used for remote control of it).
Removing the nut you can see in your bottom photo, should give you better access to where you need to spray contact cleaner.
You should find a hole for the spray pipe - for a blast within the pot itself - where wiper contacts move round carbon tracks, that's where cleaning is necessary.
After spraying, manually move the control fully up / down a few times.
Reactions: bulduzer
