- Jan 28, 2015
- 1
- 0
- 0
Hello All!
I am new here and wanted to join in because after doing tons of research and getting bombarded with the ridiculous amount of information that is out there about turntables, pre amps, speakers and such, I wanted a more refined set of recomendations. Ive narrowed down my choices a bit and because I have no local shops to go test out my options, I was hoping to find someone who is using or has used any combination of what I am looking at.
My system is going to be the following: a marantz av 5009 connected to two Def Tech SB55's. Those are pretty much set. But I need advice on my TT and phono stage choices. I am really looking at either the Rega RP 1 because of the good reviews and upgradability in the future or the Pro-Ject Debut Carbon. Now, I could reach into the depths of my patience and save for either the RP3 or Pro-Ject Essentials Carbon but I haven't seen any groundbreaking reasons to do so.
As for my phono stage, because the marantz doesn't have a phono amp, I am torn between the rega fono mini, pro-ject phono box S, music fidelity v90 or splurging and getting the pro-ject tube s.
The turntable I am willing to wait to spend up to 8 maybe 9 hundred dollars if I can find reason to do so. The phono stage I'd like to stay around/under 500. Any other reccomendations would be appreciated. Thanks!
