My first ever amplifier failure
I have never owned an amplifier that has failed whilst in my possession..... until now.
Got some new speaker cables for my birthday and fitted them to my new acquired Rotal RA1062, highly regarded by some on this forum.
Eager to listen to some music I put some on only to notice no sound out of left hand speaker.
Checked cable for continuity, it was fine.
Tried the set B speaker outputs on the amp, same thing, nothing to LH speaker.
Tried my backup speakers, same thing, no output to LH speaker.
Must be pure coincidence but seems something has failed in the amp before I changed speaker cables as it was working fine before.
Anyone know a decent repair specialist.
Back wiring up my main amp tomorrow.... ho, hum!
Sorry to hear of this. The internal fuses might have blown. You should be able to see the fuses through the vents. If so, then in the first instance please check with Rotel/B&W before proceeding to replace them.
Many thanks. I will check fuses tomorrow.
Certainly a question as to why they might have blown.
Back to saving for that Parasound Hint 6 for me I guess......
Gray
That's one of those things that only happens to other people!
Was a coincidence that it failed after swapping the cables too.
Out of several amps, I've had just the one (Marantz PM66KI) that's failed.
Another coincidence, a Rotel amp with a channel down :(
Gray
That is exactly the word I was going to use. Fingers crossed it's an easy fix.
You two Bummers are right, it's an undesirable situation.
It was both channels that just cut off while mine was playing. Power light still on, but silence.......swearing.......more silence.....the cycle repeated till I realised that swearing wasn't curing it 😞
Nothing that crude, just a sharp tap on the top. Works wonders.
Or indeed the final ' over the side float test'
I used to be the Ops director of a previous company, and technology fell under my remit. We had a nightmarish period in the very early noughties when our server royally knackered day to day activity. When (eventually) resolved by replacement, I gathered everyone outside the rear of the building and dropped the old server from my second storey window into the car park below. It didn't survive...
I can't begin to tell you how satisfying and cathartic it was - I can still hear the laughter!
Reactions: britain4
