This picture is of the full set up and taken 14ft away. The speakers are 12.5ft apart. The system is as follow's;
Chord CPM 3300 integrated amplifier which is MOSFET powered outputting 220Wpc RMS into 8 ohms, 300Wpc RMS into 4 ohms respectively.
System controller. I use this for volume control and gain setting's.
Totem Mani II Signature speakers in the now unavailable Maple. Impedance 4 ohm, frequency response 29Hz-20kHz ±3dB and Sensitivity: 85dB. The Mani's are two Dynaudio drivers in isobaric (back to back) fashion toped with SEAS tweeter.
Rear binding posts with Cardas Jumper cable's and Kimber Monocle X speaker cable.
Musical Fidelity Nu-Vista 3D CD player.
VPI Superscout Master turntable with 180gram centre weight and Mini Super Feet. The Synchronous Drive System (SDS) which is the turntable motor speed controller is situated out of site hidden behind the CD's and easily accessible for on and off power.
Dynavector XX2 MK2 cartridge.
Dynavector P75 stage and Cardas Golden Reference interconnects. 0.5 meter length to the stage the 1m length to the amp. The 1m meter length is a universal interconnect that i use with all sources.
Isotek Mini Sub and Sony Playstation 1, model SCPH 1001. The 1st generation Minisub mains conditioner has 6 sockets on the rear split in pairs. 2 for power hungary amp's and/or power amp's. 2 for digital and 2 for analog item's. The PS1 does get a look in now and then and recently have been listening to quite regular. It give's a very interesting analog/organic sound. Really quite beguiling.
Behind the scenes with various power cables as follows. 1 meter Russ Andrews Signature Powercord with W350iag plug feeding the amp. 1.5 meter Van Den Hul Mainstream BS feeding the CDP. 2 meter shielded cable feeding the Mini Sub. 1 meter shielded cable feeding PS1. 1 meter Chord iChord from AE to amp.
Thanks for your time.
