Music Streamer Next Step
ROB2009
55
Hi all
I currently have a Bluesound Node 2 connected to a Hegel H360, I only stream Tidal hifi and don’t own any cd’s, or have any music stored digitally. I don’t need Bluesound for multiroom as I have Sonos speakers throughout the house.
I’m thinking of upgrading the streamer, I don’t need a DAC as I’ll connect digitally to the Hegel and use the internal one in that.
Any thoughts or suggestions as to possible products will be appreciated.
Tonestar1
Moderator
ROB2009 said:
Hi all
If you are not using the DAC then I doubt anything will be an upgrade sound wise. You may find something with a better UI but I really can't see there being any difference in sound quality. It will make as much difference as a fancy CAT5 or USB cable.
newlash09
226
50
18,870
ROB2009 said:
Hi all
What's your budget. Aurender do some much acclaimed digital only transports.
But spending so much on a digital transport while using the inbuilt dac of the Hegel will not be a big jump in my opinion. In my humble opinion the bluesound is good enough a transport for the Hegel. So best results are with a aurender and external dac in my opinion.
insider9
Why do you need a streamer at all? You can play Tidal directly to your Hegel amp and files over Airplay and DLNA. I know Bluesound/Sonos has a far better interface but BubbleUPnp works absolutely fine. Have you tried it?
