Music centre/Dansette/all in one record player kind of equipment
HenryRoot
I have a modest selection of vinyl I want to leave in a guest bedroom with an all in one record player, as a bit of a fun way for guests to ve able to listen to some music. Doesn't have to be brilliant sound quality, but I'd like it not to be cheap-sounding rubbish.
Anyone got any ideas about the sort of solutions or bits of equipment I should be looking at. Up to about £400 for the whole thing, but preferably cheaper.
Thanks.
Thanks. Nice thought. But are there any good modern versions of the same idea, with decent stereo and a better sound quality?
Nothing apart from a couple of Dansette type copies (by Steepletone) that aren't stereo and won't sound as good as the valve powered originals.
A Google search brought this up...
Clicky.
It has six 6 five star feedback user reviews and it is made by TEAC so who knows? It might be quite good.
Built-in speakers too...
I'm not saying it's any good (i've never heard one) but it's the only one-box, all-in-one, brand new, stereo, record player system I can find that is made by a serious audio company.
I can see what you're wanting to do and I like the idea, but there's only one way to make the impact you want to make and that's with a classic player from the 50s/60s. Anything modern will look you've plonked a cheap music-centre in there for no real reason. Dansettes are the obvious ones but because they're the most collectable they're the most expensive. Consider other makes from the same era like Pye, Ferguson, Bush and Dynatron. And imo it doesn't need to be stereo.
Thanks all. If I was going to go for a better sound quality option for the same money, any recommendations?
Go on ebay and search for Beocentre.
A bit different from the Dansette but does the same thing.
