I've owned a Naim Super Uniti for around 6 years now. The unit is paired with a couple of Focal Aria 936 speakers. I'm looking for an upgrade from the Super Uniti. I have a couple of questions which i hope will help me make up my mind on the best path to take.
1, The Super Uniti sounds great but it's getting a bit old in the tooth now and i want something that supports Roon and the new Tidal connect, Naim are updating their range early next year with firmware for Tidal so i was wondering whether to buy a Uniti Nova or a NDX 2 streamer? Or any other recommendation.
2, On top of the £5000 i want to spend on a streamer should i pair the Naim with an amp.( Naim NAP 200 Dr or 250 DR)? or any other recommendation. Would this significantly improve the sound?
3, Should i forget the £2500-£4000 on the amp and instead upgrade my basic speaker cables?
I'd like to keep the total costs to anything between £7000-£9000.
I really hope I've put all the information needed in and look forward to any responses.
Neil
Neil
