- Jan 9, 2012
- 39
- 0
- 0
relocated said:So where is yours then?
igglebert said:Apologies but I think a forum upgrade destroyed some of the formatting and I don't want to add it in case it bumps it to the top and I get annihilated for reviewing an AVI product.
The_Lhc said:igglebert said:Apologies but I think a forum upgrade destroyed some of the formatting and I don't want to add it in case it bumps it to the top and I get annihilated for reviewing an AVI product.
<SPEAK AND SPELL> Can you spell "MASSIVE OVER-REACTION"? </SPEAK AND SPELL>
Seriously, not going to happen, get over it, nobody cares (much).
Paul Hobbs said:igglebert said:Apologies but I think a forum upgrade destroyed some of the formatting and I don't want to add it in case it bumps it to the top and I get annihilated for reviewing an AVI product.
Id like to read it, but I'm terrified of that huge block of text in your first post![]()
igglebert said:The_Lhc said:igglebert said:Apologies but I think a forum upgrade destroyed some of the formatting and I don't want to add it in case it bumps it to the top and I get annihilated for reviewing an AVI product.
You'd think.
Nice to see you're as charming as ever, the_lhc :wave:
The_Lhc said:nobody cares (much).
relocated said:The_lhc,
If you are going to refer to yourself as an a****hole could you please use the correct term as I have used. We don't need word mangling from 'across the pond', as in a**hole.
Sits back to ride out the storm.
:cheers:
relocated said:If you are going to refer to yourself as an a****hole could you please use the correct term as I have used. We don't need word mangling from 'across the pond', as in a**hole.
BenLaw said:relocated said:The_lhc,
:cheers:
FOUR asterisks?!?
John Duncan said:Never mind all that. I'd like to know how four stars can be applied to The_Lhc when his constituent parts (90% water and some carbon) can only cost 2/6. Anyway, maybe he meant angsthole; he is a worrier, after all.
Clare Newsome said:Play nicely now, please
Back to the OP - reminds me, have been meaning to post pic of some of my vintage kit....
