Alears:Tarquinh:Taylor74:
My concern is that the amplifiers are tying you down.
You have "invested" £3k in amplification, so you want to base a system around that combo.
However, with the addition of a small passive two-way, like the ATC or ProAc, the total system cost will be almost £4k.
Think of the active monitors at that price point.
How do you honestly think the two will compare?
Why are you banging on about this?? The OP has made his position quite clear. He doesn't want active speakers, never did, so let it rest there.
Personally I'm with Dan and would save for better speakers. That's fine amplification and something like the Dynaudio contours would be an excellent match.
Tarquinh,
Very delicately put! But your are right. You mentioned the Contours and these did not make my original list as I was informed that they need to be placed further from the rear wall than I could possibly put them. Or do you know different?
Yes sorry about that, am a bit tired now after a short cycle ride turned into a 50 km marathon on a hot day!
If they have to be placed near to the rear wall then the ATCs are your best bet. The Dynaudios need about a metre, else you have to use the foam bungs.
