Hi, I am looking to upgrade my speakers to the following Monitor Audio pl200 and centre plc150 and am planning to use the Silver RXFX for my rears and RXW12 as my sub.
So here are my questions (I am home trialling the PL200 and am convinced that these are the speakers for me)
Any ideas/thoughts on speaker wire upgrade, I am currently on QED Silver anniversary which sound good, but I think an upgrade would be worthwhile.
Also will the rears work well with the platinum - I really need wall mounted as oppossed to bookshelf.
Is it worth upgrading my REL Quake, will I hear much difference? I also have the GX150 on home trial, is there much difference in the PLC150 and GX150
Finally does anybody know any places with good January deals or discounts on Monitor Audio kit (I dont mind B-Stock or used if it helps to keep the budget down)
Also any thoughts, help and advice would be really appreciated.
Many thanks
Lee
Many thanks
Lee
