Monitor Audio GS LCR Centre
FrankHarveyHiFi:
It's hard because I don't know how yours sound.
If you feel the bi-amping made a large enough difference, stick with it. If there wasn't much difference, I'd try a better cable to get a bigger difference.
TBH David, I had the Mission predecessors bi amped and when I replaced them with the RS5's I just plugged in the same speaker cables. I have no idea whether they'd sound better single wired, bi wired or bi amped........guess I should take some time to listen with different variations although I can't tes the bi wired option as I have no suitable cables
If you are happy bi-amping/bi-wiring your fronts, leave them as they are. If the cable to the cenre is short, just bi-wire them, I would
