Mix and Match 5 Speakers with Different Brand Subwoofer
Hi All,
I am in the process of setting up a Home Cinema room and I am looking at the B&W MT speakers system without the supplied B&W Subwoofer and getting a Veloydyne Subwoofer (SPL 800 R ) as an alternative
My question is does it really matter if all your speakers are not from the same manufacturer?
The AV Receiver I will be getting will be the Denon 2808 when it is finally launched.....
Clare Newsome
1,657
Hi there,
The subwoofer is the permissible exception to the rule that all speakers in a surround set-up should ideally come from the same manufacturer's range (so they have the same sonic signature).
The Velodyne would be better than the sub that comes as standard with the B&W MT-20 package, but is no match for the glorious B&W PV1 that comes with the MT-30s. There's hardly a surround package around that wouldn't sound better with the PV1 on board....
And I know what you mean re the Denon 2808 wait! Sadly we won't be able to run a test of that until mid-October.
