John Duncan said:oooOOOooo.
(by the way, don't google 'oooOOOooo' to try to find an appropriate image)
Whoah!!! :O
(That was like a big red button with 'DON'T PRESS')
the record spot said:davedotco said:The_Lhc said:davedotco said:Personally I think we need to differentiate between the term hi-fi as used to describe TVs, Phones and hi-fidelity which is something else entirely, at least we can then have discussions where everyone knows what is being discussed.
So, you can't simply tell what's being discussed just by reading the discussion, you need it labelled? I don't think anyone else has that difficulty. At least I've certainly never noticed.
Well I have, many times.
For example, I mention something that I think is important in hi-fi terms and get told that it doesn't matter one jot as long as the owner likes it.
Whilst personal preference is a perfectly acceptable way to choose an enjoyable (to the user) music playing system, it is not sufficiant to select a hi-fidelity playback system. I think this is self evident but others do not, simply because the words 'hi-fi system' means something very different to me than it does to them.
Just one simple example.
I think we can achieve high fidelity very easily these days. Certainly way easier today than it was not so long ago now. Performance, through technology advances deliver us that high fidelity. Picking up an iPod Touch, sticking 20Gbs worth of WAV files on it and some half-decent headphones and you're away. A FLAC file on a USB stick through the Onkyo and it's terrific. The sound quality is all there.
Most of the battle is in the mastering and originaly recording; thereafter the notion that one had to, or still has to, spend a small fortune to get high quality playback is an utter fallacy.
davedotco said:I am aware that others see things differently, but we are told, on this very forum, to trust in what we hear and this is what I hear.
Craig M. said:John Duncan said:oooOOOooo.
Whoah!!! :O
the record spot said:That's fine for you Dave, as you see it. I'd believe differently. I guess mostly as I hear it day in, day out. System cost below? Just under £2000 at full RRP. Hi Fi is full of opinions, but fidelity to the original recording is way easier today than ever it was. And significantly less hassle too. I've got the lot going through the 818, I've bi-amped my speakers and while the Onkyo isn't the last word in compact design, the sound quality it delivers is well up there.
Rather like Jimmy Hughes who used a Denon DVD3930 for his day to day listening (another great machine - I have one), gear like the 818 (and others like it) clearly show that high fidelity isn't a distant consideration for manufacturers.
chebby said:MajorFubar said:For some people it really is the end of the world if their new amp can't stream music from their iDevices via Airplay, irrespective of how well it sounds.
And it sounds very 'well' indeed 🙂
I just wish hi-fi could have been this much fun 20 years ago.
AlbaBrown said:John Duncan said:None of this junk adds to the quality of reproduction achieved (sends it barreling the other way!).
I disagree.
I disagree.
davedotco said:I use as much modern technology as anyone, audiowise anyway, it is tremendously convenient and as someone who constantly craves 'new' music I use spotify a lot.
Macbook or iPad via Airplay into is how I listen to most of my music these days, I accept and enjoy it for what it is, but it is not, to my mind, hi-fidelity reproduction, by my definition anyway.
the record spot said:You had a budget of £2k and you knew Jimmy Hughes as well Dave? Fancy that! What are the chances eh...
MajorFubar said:Dave I think you've got a lot of good things to say, some of which I agree with, it's just unfortunate that sometimes you put it across in a very aloof way. Even I've found myself on the receiving-end of your sharp tongue, bizarrely on an occasion in another thread when I was supposed to be agreeing with you. But I do enjoy reading your posts, mostly, and I respect your obvious knowledge of the subject matter.
Carry on.
davedotco said:Macbook or iPad via Airplay into is how I listen to most of my music these days, I accept and enjoy it for what it is, but it is not, to my mind, hi-fidelity reproduction, by my definition anyway.
The_Lhc said:davedotco said:Macbook or iPad via Airplay into is how I listen to most of my music these days, I accept and enjoy it for what it is, but it is not, to my mind, hi-fidelity reproduction, by my definition anyway.
Take out the Airplay and the rest of it is irrelevant, a Macbook delivering Lossless files to a DAC via an optical connection (for example) isn't going to sound any different to a CD player deliver digital audio to the same DAC. It's everything downstream of that that will determine if it's "hi-fi" or not.
Last year's KEF demo rig at the Bristol Show was exactly the above into an Electrocompaniet amp driving the Blades. If that isn't hi-fi then I'm not interested in hi-fi. It was extraordinary.
davedotco said:The_Lhc said:davedotco said:Macbook or iPad via Airplay into is how I listen to most of my music these days, I accept and enjoy it for what it is, but it is not, to my mind, hi-fidelity reproduction, by my definition anyway.
It is the Airplay that is the point....... :wall:
Even through my very simple system the Macbook via optical is better than the iPad via AEX, a dem I have done several times as it is very easy to set up.
However I still use Airplay for the convenience, streaming the Associates (live) as I write this. On the other hand, with a decent system this would not be acceptable (to me) for serious listening, with my current system neither produce hi-fidelity so it doesn't much matter.
The_Lhc said:davedotco said:The_Lhc said:davedotco said:Macbook or iPad via Airplay into is how I listen to most of my music these days, I accept and enjoy it for what it is, but it is not, to my mind, hi-fidelity reproduction, by my definition anyway.
That's why I said take it out, it's re-sampling everything to 16/48 for a start.
That was my point.
Well that's your choice to do that even though you know it's inferior, I don't understand in that case why you would seek to lump the Macbook in as "not hi-fi" when it's perfectly capable of being so. That's not very scientific of you, the macbook isn't the problem.
davedotco said:MajorFubar said:Dave I think you've got a lot of good things to say, some of which I agree with, it's just unfortunate that sometimes you put it across in a very aloof way. Even I've found myself on the receiving-end of your sharp tongue, bizarrely on an occasion in another thread when I was supposed to be agreeing with you. But I do enjoy reading your posts, mostly, and I respect your obvious knowledge of the subject matter.
Carry on.
Genuine apologies if I was a little too sharp, I am use to fora that allow a little more in the way of 'banter' and 'rough and tumble', though I have been trying quite hard recently to be polite.
I do find it a little difficult on occasions with some of the rubbish that is posted, mostly I just 'bite my lip' and do not get involved but there are occasions where I feel I have to say something. Being scientifically trained I tend, particularly when correcting errors of fact, to be quite precise and say what I mean and I get pretty annoyed with some on here who then give me grief for things that I have, quite specifically, not said,
I am also somewhat miffed (see, very polite indeed!) when I am called a liar ( not yourself) when recounting a little anecdote from my years in the business, but hey, this is the internet so there is not much I can do.
Edited for spelling.
davedotco said:The only point to clarify is that although I do consider my Macbook to be real hi-fi (I never said differently),
the record spot said:Dave,... Your posting style makes it look like you know better than anyone else, with an unfortunate arrogance in tow. You are what we'd call locally as "The_Lhc".
davedotco said:The_Lhc said:[...]
the record spot said:davedotco said:MajorFubar said:Dave I think you've got a lot of good things to say, some of which I agree with, it's just unfortunate that sometimes you put it across in a very aloof way. Even I've found myself on the receiving-end of your sharp tongue, bizarrely on an occasion in another thread when I was supposed to be agreeing with you. But I do enjoy reading your posts, mostly, and I respect your obvious knowledge of the subject matter.
Carry on.
Seeing as I think you might be referring to me in your last paragraph all I will say is this: I felt it was quite the coincidence that right after I posted my comments around a £2k system and a passing comment around the Denon player Jimmy Hughes once had, you came back with how you once had a £2k budget too and just happened to meet Jimmy as well. Namedropping the "J M" for good measure.
Dave, I respect your views on some things but on others you leave me cold. Your posting style makes it look like you know better than anyone else, with an unfortunate arrogance in tow. You are what we'd call locally as a "bit of a blaw".
