Mini HiFi components for my home office.
n4d5
54
Hi all
Hope you are all safe and well.
Currently I have a Pioneer A400 amp and Jamo speaker setup with a Chord Mojo streaming music from my laptop. Unfortunately my amps volume control is going up the creek, I have tried cleaning it however no such luck!
Can anyone recommend mini components to replace my amp? I don't mind looking at second hand gear. I need the ability to stream music if possible, or I can do what I already do to stream music. I would like to have a dab radio to built in or a separate component.
Form factors important it has to be a mini size component. Budgets upto £400.00. Components need to sound as good as or better than the Pioneer A400.
Look forward to your suggestions and comments. Thank you in advance.
n4d5
54
Denon make some pretty decent mini systems. You might struggle to find one to better an A400 though.
Is it going to be driving those Jamo Speakers or are you looking at getting desktop ones?
The Jamo are actually a 2.1 satellites and subwoofer which works well. So I won't be changing the speakers for now.
I'll look into Denon mini components thank you for the suggestion
