Hi there.
I have the setup in my signature that i am using. It works well together. I would like to ask whether or not a second subwoofer would be likely to add anything to the setup?
Also if a second subwoofer is to be added would you use a similar subwoofer with similar frequency range or add a different type?
Any input appreciated, even if you just tell me not to bother getting a second tx
