mains cables r us:
Hi Clare,
The review was only a short one, I only posted here because I used the cable myself and thought it was very good, your review stated quite clearly that you put the cable in your reference system, my point, which I think is a fair one is that cables sound different depending on your components so if this cable sounds bad with your system it may not in others, is that a fair point? Finally you only listened to one album or cd which again is not a comprehensive review is it? If you did listen to more the review should state that, many thanks.
I'll repeat again - we always test with both a reference system and price-comparable kit. And always with a range of material. That's the same for every single WHF test.
It's a short review - we don't have room to list all the discs/kit used, so we mention examples of both.
