Marantz PM7200 Buzz Sound(Like a radio during tuning)
nikhilsivan
On both channels
Even when volume is 0
Constant noise on all volume levels
On both A and AB modes
podknocker
802
665
2,770
Sounds like a dirty volume control, although odd that you hear it at zero volume.
Even so, try to get some electrical contact cleaner and clean inside and around the volume control.
IF it's out of warranty, then there's no harm in opening the unit and cleaning it.
I had a noisy volume control on a Quad Vena 2 but sadly , the ALPS motorised pot was a sealed unit, so would need sending off for repair. I ending up giving the amp away.
The contacts inside these things can pick up dirt and they do oxidise quite quickly.
Stuart83
101
68
170
Yes I agree, had this on two amps, cleaning only helps for awhile as it's contact wear not necessarily off over use
