Marantz pearl lite amp trouble
Where are we up too ? Did that all that make sense ?
What I was trying to say was that the reading of 1.0 could be close to the point where the meter would change to display 1.1 That would be good if so. Conversly the 1.1 reading could be almost ready to change to 1.2 which would make the error a bit worse.
So we can perhaps gauge that effect by carefully altering the balance control to equalise the left and right readings. It should be a minimal amount that it needs turning. Keep tweaking the volume to get the meter to just change from one reading to another and see how close the other channel is to that point.
My feeling up to now is that it all seems OK though.
Did you notice any acoustic effects (level changing) as you moved around the room with the tone playing ?
Yes that all makes sense.
I have done as you say and it looks like good news. The left side is only just at 1.1 and does occasionally go back to 1.0 matching the right side.
When upping the volume the difference stays at .1
Im am going to keep hold of the meter for a while incase there is an intermittent fault as the left hand bias has been quite obvious at times. At least I can now check again if it returns.
The acoustic effect you mention is quite strange and only small movements has a big effect.Perhaps this was what I was experiencing after all.
Thanks for all your help with this, it really is most appreciated.
You only have to move a tiny bit to hear the effect of the cancellations etc... good isn't it 🙂 It makes you realise what a huge effect the room must have on the overall sound you get.
Well all the measurement results sound good to me. Obviously keep a check and when you feel it isn't correct then you can just pop the disc in and see.
I really do think the amp is 100% OK.
on Amazon.com there is a review from someone about the pm 8004 (= pm lite) with this problem too.
Hi vonchief,
Did you sort out your issue with pearl lite? I've got the same amp / sacd player and very similar problem, the right channel is slightly louder than the left one. I swapped the cables, tried both 'A' and 'B' amp outputs, used a different source and it's definitely the amp. The results are consistent, the right (or when cables are swapped, the left) speaker is louder. It is particularly noticeable at the lowest volume.
Did you end up replacing your amp?
Thanks.
