Hi, i wonder could i ask another couple of questions from the helpful and knowledgable users of this forum.
I have got the MCr-610 up and running, and it is indeed an excellent little unit, and very versatile, though i think i will invest in new speakers as my old Mission 760is,i think, don't do it full justice, as i feel i don't get all the detail and clarity it is capable of, as other users have experienced.
My questions are....I am using it through wi-fi at the moment, but when i tried to connect it to the Bt Homehub router via ethernet cable....it just will not connect, and i eventually get a "check network cable" message. I can't figure out why this is? are there any settings to adjust?
Also, when i try to login to Spotify, it will not load till i go through the setup process and use the password and connect wi-fi up again. Do i have to use the Quick Set up process every time and set up wi-fi manually, or am i doing something wrong and can i keep wi-fi on all the time and just login easily to Spotify without having to go through the tiresome process of the Quick Setup?
My final question relates to the Marantz Remote App which i have downloaded to my mobile.....When i try to "Add Devices" to it...the MCR-610 will not appear on the device list. I tried entering the IP address of the machine to the app, but have had no luck, and so the remote app will not work.
Any help will be much appreciated....Callum.
