C clacky Member Oct 12, 2020 1 0 20 Oct 12, 2020 #1 hi i have the above with tons of music on usbx2 on it. the question is i only use it at about an hour at a time. why will after turning it back on it does not start playing where i left off so i can listen to all my music eventually thank you
Al ears Well-known member Nov 23, 2008 14,104 8,650 64,070 Oct 12, 2020 #2 Presumably because you clear any memory, if it actually has any, when you switch off and memory sticks don't have a memory.
D Davywhizz Active member Sep 30, 2020 18 6 25 Oct 12, 2020 #3 I didn't know it has a memory. I've only used a usb stick a few times with mine and used the Marantz app to select albums/tracks.
Al ears Well-known member Nov 23, 2008 14,104 8,650 64,070 Oct 12, 2020 #4 Davywhizz said: I didn't know it has a memory. I've only used a usb stick a few times with mine and used the Marantz app to select albums/tracks. Click to expand... I did say , if it has any.... I doubt anything you are using has a memory function
D Davywhizz Active member Sep 30, 2020 18 6 25 Oct 12, 2020 #5 I was agreeing with you - I've had one for years and never seen it mentioned anywhere.
