marantz cd63 ki
lewis hurlin
34
I am looking at buying a marantz cd 63 ki and jus a bit worried which one i am buying the picture has the ki logo as the signiture and the majority of the ones i have seen have the lgos on a solid brass plaque. is it a mk1 or mk2, what is the difference in sound quality ?
Get the one with the brass plate, that was the latest incarnation by KI of the CD63, excellent CDP as well.
thanks i thought that was the case i will try to get one over the weekend should sond cool with my audiolab 8000 a & p combination. what are the weak points if any on this cdp?
Only weak point is that most of these players will be over 10 years old and the mechanisms might be on there way out, if you don't mind a repair bill them fine! Sonically they are a great player I can't help thinking you would be better of with a CD6004 with a 2 year warranty IMHO.
I've had my CD-52 for twenty one years and it is still playing fine , so a ten to fifteen year old player is just a baby . I assume mine is a lesser player than the CD-63 so I would like to think that there would be lots of life left in any player you might get .
