Al ears said:People's definition of warm is obviously arguable. You should look for a second hand Primare integrated, in my opinion. If you must buy new then the Marantz is hard to beat.
S83 Trike said:Vladimir said:I'd go for Yamaha rather than Marantz for more holistic, warm, analogue sound.
Even the Yamaha AS 701 or 801?
QuestForThe13thNote said:The thing is the extra detail of a cyrus or Rega etc help the speakers be a better one than they are by taking them up a stage, to similar to what really good premium hi Fi is like which is more expensive ie detailed but balanced and dynamic. Otherwise it’s just the usual bluuurrrggghhh....
You have to really mismatch the speakers to the amp to get tiresome treble ie speakers that really really don’t go together, and I don’t think that’s the case with the one. Tannoy is expansive and good soundstage and quite balanced. You don’t want to aspire to reductions in detail for the sake of possibly being too high on treble, and the Cyrus ONE works with lots of speakers and the combinations are not too high on treble. A lot of what’s ebjoyable with hi Fi and music is it’s revealing nature. Get an amp that can do that, and you start enjoying all the stuff you never once heard.
A lot of audiophile ista people listen to hi Fi which is the usual bluurrghhh (sorry didn’t spell it the same this time). It’s always on the side of bass knob up plus 2 or 3 and treble minus 2 or 3. It’s not a good balance and for getting stuff the artist intended - the detail, also doesn’t tend to help with the dynamics of music.
Vladimir said:QuestForThe13thNote said:The thing is the extra detail of a cyrus or Rega etc help the speakers be a better one than they are by taking them up a stage, to similar to what really good premium hi Fi is like which is more expensive ie detailed but balanced and dynamic. Otherwise it’s just the usual bluuurrrggghhh....
Cyrus management just sent me this message for you: "PLEASE STOP HELPING!"
*biggrin*
Al ears said:Vladimir said:QuestForThe13thNote said:The thing is the extra detail of a cyrus or Rega etc help the speakers be a better one than they are by taking them up a stage, to similar to what really good premium hi Fi is like which is more expensive ie detailed but balanced and dynamic. Otherwise it’s just the usual bluuurrrggghhh....
*biggrin*
Are they having difficulty keeping up quotas? 🙂
the Yamaha A-S801 is the newest to the range and supports onboard Dac .......Vladimir said:S83 Trike said:Vladimir said:I'd go for Yamaha rather than Marantz for more holistic, warm, analogue sound.
No idea about those, but I remember some complaints of the 700 predecesor being a bit overdone in the warm and cosy department. The step up to 1000 was prefered.
I30 was the follow up to A30.1. Very well regarded model. You'll be able to find quite a bit of info on the Internet about it. It would be superior to most if not all amps mentioned in this thread. Fully balanced high current, dual mono design that can deliver 40 amps of current and will drive even very demanding speakers.S83 Trike said:insider9 said:Well I wasn't going to mention Primare since all the gear suggested was new. Class AB Primare is a perfect partner for Tannoys. I've hear both in my own system Primare A30.1 with Tannoy DC6T and recently suggested the same speakers for my mates Primare A20. What these amps do so well is build on strenghts of the speakers (soundstage) and don't show up their weaknesses (treble that can turn harsh quite quickly). I wouldn't suggest any Class D amplification with these speakers especially Cyrus One that has crisp and clean sound as per WHF review. It's likely to cause fatigue with harsh treble being the star of the show. I've heard my Tannoys on the end of Class D amp and it was unlistenable without the use of tone controls.
Should I look for one I'd go with I30 the last Class AB integrated from Primare and the most raved about.
The Primare sounds good, but i do have to go S/H and the only ones coming up are I30 models, are these similiar to the A30.1?
yamaha ....Dynamic Power: (8/6/4/2Ω), 140/170/220/290Winsider9 said:I30 was the follow up to A30.1. Very well regarded model. You'll be able to find quite a bit of info on the Internet about it. It would be superior to most if not all amps mentioned in this thread. Fully balanced high current, dual mono design that can deliver 40 amps of current and will drive even very demanding speakers.S83 Trike said:insider9 said:Well I wasn't going to mention Primare since all the gear suggested was new. Class AB Primare is a perfect partner for Tannoys. I've hear both in my own system Primare A30.1 with Tannoy DC6T and recently suggested the same speakers for my mates Primare A20. What these amps do so well is build on strenghts of the speakers (soundstage) and don't show up their weaknesses (treble that can turn harsh quite quickly). I wouldn't suggest any Class D amplification with these speakers especially Cyrus One that has crisp and clean sound as per WHF review. It's likely to cause fatigue with harsh treble being the star of the show. I've heard my Tannoys on the end of Class D amp and it was unlistenable without the use of tone controls.
Proper 100Wpc into 8ohm and 180W into 4ohm.
sorry I robbed the spec from a site and it was the best spec I came across as most sites never give the full spec sheet probablyinsider9 said:You forgot to mention these rather important two
Power consumption 600W max Peak current ±40A
Blacksabbath25 said:sorry I robbed the spec from a site and it was the best spec I came across as most sites never give the full spec sheet probablyinsider9 said:You forgot to mention these rather important two
I would try anything as long as it’s good I am still a man in love with my Yamaha and can’t ever seeing myself changing it ever I even thought about buying a back up one bit crazy I know but it’s taken me years to find something that really floats my boat .insider9 said:Blacksabbath25 said:sorry I robbed the spec from a site and it was the best spec I came across as most sites never give the full spec sheet probablyinsider9 said:You forgot to mention these rather important two
I know 🙂
Yamaha AS-801 is certainly a very good amp and it would much easier to buy as it could be returned. Not just that it does come with a DAC. I have a sentiment when it comes to Primare gear. I'm sure you'd enjoy it immensly Sabbath it would pair really well with your Dalis.
I30 is more on par with AS-2100. I'd struggle choosing between the two.
