Benedict_Arnold said:Your hardware has to be able to play mkv files. Otherwise you might as well feed them the shipping forecast transcribed onto papyrus.
daveh75 said:Benedict_Arnold said:Your hardware has to be able to play mkv files. Otherwise you might as well feed them the shipping forecast transcribed onto papyrus.
It's not that simple.
MKV is just a container format with support for just about every audio, video and subtitle format under the sun, meaning pretty much limitless combinations.
Therefore just because a player claims MKV support, that doesn't mean it will necessarily support the formats contained within.
Roku is a case in point, it claims MKV support, but is actually has quite limited support for codecs IIRC.
As good as the Roku is for SVOD/Catchup it isn't a particularly good frontend for 'local' media IMO and really requires Plex or similar backend to do transcoding to make it usuable...
Andrewjvt said:I'm getting an AV reciever tomorrow and a Sony Blu-ray.
Do you think I'd be better off getting the nvidea shield TV instead of the blu ray for the mkv playback?
Only £50 difference so not a problem and I already have an older player.
Also.a question regarding the nvidea TV.
If I'm using my laptop to use mkv and transfer into usb hd Will it work on the nvidea
As I thought I read you need to format the usb hd for use on the nvidea before it will work.
So basically using my laptop to transfer files to the usb hd
Is that ok operation or do I have to connect my pc directly to the nvidea TV and leave the usb hd plugged into the nvidea TV instead?
daveh75 said:Andrewjvt said:I'm getting an AV reciever tomorrow and a Sony Blu-ray.
Unequivocally yes. Disc spinners are sooo the 'noughties'
Its only a problem if you use a drive as internal storage as the Shield then encrypts the disk IIRC.
Not a problem if you mount it as removable storage though, and the Shield TV supports exFAT, FAT32, NTFS and HFS+ so there's no problem with drive formats and swapping between your laptop and Shield.
Assuming you're using windows then NTFS is your best bet so you don't run afoul of the 4GB file limits of FAT.
Andrewjvt said:Adding a nas Don't know what I was thinking messing around with external usb hd
