reggaedave:
Im going to make one at work. Plug top ( there will not be anything special there im telling you)..
Cable, ill use a 3 core wire wound cable, that will be shielded with alu foil, and all cores covered with a silver braid. ( i can understand a little with this spec, but wouldnt have thought it would be doing much over a short distance, maybe a long run, but ill go with it)...
Ill have to have a look at whats goin on at the kettle lead end, unless there's summat inside a expensive one it should just be normal? anyone?
Nope a standard IEC connector (not a kettle lead), is fine if you can get one with silver connectors it may sound different give it a go and experiment. The shielding prevents any unwanted RFI or MFI entering the system. Imagine an FM radio with no aerial, very poor signal......now add "only" 0.5- -1.0m aerial,much better signal.............see where I am coming from????
